didn't get Christmas bonus text
Arrbilly
Hi.   I didn't get Christmas bonus text.  How do I go about getting it?
8 REPLIES 8
Arrbilly
Problems resolved!  Thanks for the replies.  Happy New Year, everyone!
regards
          R
@Arrbilly
The website has problems with caching and seeing old information in your account.
Try logging into your account using a different browser in incognito or private mode instead.
Then do a refresh of your overview page, by clicking on the little circular refresh wheel.
@Arrbilly   make sure you check the Community inbox https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage for Support's reply
Arrbilly
Hi All
Thanks for the replies.  I've submitted a ticket and hope to get a reply soon as I also discovered that I hadn't gotten the new program I'd signed up for a few months ago and had received a confirmation of.  Guess I should check my account more often...
Hi @Arrbilly
you can add it back easily and quickly with chatbot, just follow the exact sequence on Chatbot and you will be able to submit the ticket
at : https://publicmobile.ca/chatbot.
First type Missing Bonus
Then click the only choice   My Bonus is Missing
Yummy
Contact agent to add it manually.
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
Quigley
@Arrbilly
Try sending YES2 to 4911
If that doesn't work, then you'll have to ask for a Customer Support Agent to add those holiday gifts to your account manually
Use the Chatbot Simon to get a service ticket started first.
You'll find the link at the bottom of this page.
@Arrbilly
first try to send YES2 to shorcode 4911
if you got back a reply saying they will add it, good
if not, then just open ticket with PM Support and they will add it back for you.
Please  open a ticket via Chatbot for PM Support :
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
