07-15-2022
10:43 PM
07-16-2022
07:31 PM
Dunkman
hi i recently bought a uniherts phone, i put my Public mobile sim card in, I have service, texting and calling works but my data doesnt, its turned on but there is no symbol at the top showing it and it doesnt work, its been like this for over a week now. any ideas anyone thanks
07-16-2022 05:24 PM
Hello there! I hope your day is going well!
The system will automatically close the conversation in 24 hours if there is no reply.
I am doing this follow up to see if you have any other concerns.
Kindly,
Leonardo, CS_Agent
07-16-2022 09:11 AM
Hi there!
My name is Leonardo and it will be my pleasure to help you today.
Please create a new APN with the following data:
Name PM
Proxy Leave blank.
Port Leave blank.
Username Leave blank.
Password Leave blank.
Server Leave blank.
MMSC proxy 74.49.0.18
MMS port 80
MCC 302
MNC 220
Authentication type Leave blank.
APN type default,supl,mms
Please do not forget to SAVE at the end of the operation
and restart your phone.
If you have any other questions , I will be at your disposal.
Kindly
Leonardo CS Agent
07-15-2022 11:14 PM - edited 07-15-2022 11:15 PM
@hwinne9j8 wrote:Hi thanks for replying
so on my apn settings
under name it says "Telus SP"
under APN it says "sp.telus.com"
proxy is 74.49.0.18
port says 80
I doesnt show the protocol
my apn enable/disable is greyed out
mvno type is none
mvno value is greyed out as well
other then that its the same as you showed,
its significantly different would that be the issue?
Both Proxy and Port should be blank
MVNO type:GID
MVNO value: 4D4F
If some are greyed out, you might need to create a new one and follow what I suggested above
07-15-2022 11:11 PM
07-15-2022 11:09 PM
yes its Android, I did the network reset no change though
07-15-2022 11:08 PM
proxy is 74.49.0.18
port says 80
mvno type is none
07-15-2022 10:46 PM
@hwinne9j8 never heard of this brand. Android?
try Network Reset
07-15-2022 10:45 PM
@hwinne9j8 this sound like the phone might not have the proper APN settings and/or missing necessary bands for used on PM
Check the APN setup, you can compare to this:
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MMS Protocol: WAP 2.0
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms,agps,supl,fota,hipri
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type:GID
MVNO value: 4D4F
