07-13-2019 04:48 PM - edited 01-05-2022 05:52 AM
07-15-2019 10:43 AM
As long as I've been here, the BONUS data listed without AutoPay is exactly that. It is added to the plan whether or not you use AutoPay.
If you can find a better option in the plan builder than on 30- or 90-day cycle, than the 30-day ready-made plans, go for it.
07-13-2019 08:10 PM
07-13-2019 06:11 PM
@DaveMcC I don't think Build your own plans have data bonus on autopay, you do get $2 though. If you look at the prebuilt plan the data bonus is added on explicitly.
07-13-2019 05:07 PM
@bravo_md wrote:It would work just the same.
Things at Public Mobile don't always work as expected. It depends on how the system has things coded. All we can say for sure is that the advertising makes no mention of an autopay requirement for the data bonus when making a build-your-own plan.
07-13-2019 05:00 PM
07-13-2019 04:59 PM
The regular plans specify you must have autopay but the build your own data section does not. Does it specify this anywhere else on the website or is it just an assumption that would work the same?
07-13-2019 04:59 PM - edited 07-13-2019 04:59 PM
@DaveMcC wrote:Does the data "Bonus" for the 6, 12 and 18 GB options in the Build your own Plan section depend on having "Autopay" like in regular plans or is it just a current bonus to promote that amount of data purchase with no autopay requirements ?
I do believe that Public Moible intended to advertise such bonus in the plan builder to require autopay, just as with the Ready-Made plans. However, you're correct that it doesn't say that.
07-13-2019 04:53 PM
@DaveMcC In order to get the Data bonus you must have AutoPay enabled.
07-13-2019 04:51 PM
Data bonus is with auto pay.
