01-21-2022 09:12 AM
I update my credit card as the credit card date expired.How long it take to reactivate my phone
Payment
01-21-2022 12:31 PM
If you updated your CC before renewal date, all is set up.
But if your service was suspended AND then you updated your CC then you have to pay bill manually topping up to plan cost and service should be reactivated.
01-21-2022 09:20 AM
Now that you updated your card if your services are suspended you must make a manual top up payment to cover your plan amount. ie. $25. Go to the payment page. Choose other amount. Enter your payment amount. Confirm and submit your payment. Your service should automatically reactivate.
If it does not then go to the plan's or usage page. Click on lost/stolen. Suspend your service. Log out/in. Resume your service. Your plan will now be automatically reactivated. Log out and reboot your phone.
01-21-2022 09:16 AM - edited 01-21-2022 09:18 AM
@Ghan53 After an Autopay failure, PM won't trigger another one automatically.
In this case, You have to manually make a payment now to reactivate your service
Please login to My Account, Payment Tab, One time payment
First try to pay by Amount Due, if it works, good
If it didn't go through, then try again with "Other (Enter the desired payment amount)" option and manually enter your Plan Amount.
Once payment made successfully, check if there is a button "Reactivate current plan" still there, if so, click on it
Then logoff from My Account and Reboot the phone and it should be good
