charges for exceeding plan
Raymondi
My plan is $10/mo for 50 minutes. Never had to exceed, hower Teul land line out of service for 4 days and tech help is coming to house tomorrow.  If I exceed my 50 min. how much per minute will I be charged?
Thanks guys,
Raymondi
7 REPLIES 7
emad
Either purchase Add-on long distance or contact the moderator team to renew your month earlier
@mh1983 wrote:
There are at least 3 answers that say the same thing. 🙂
Unfortunately, it's impossible to know what someone else is typing while typing your own message which can take a few minutes.  At least it's not stuff being repeated multiple days later.
That's because all three were responding at the same time without being aware of the other posts. Nothing you can do about that.
mh1983
Thanks guys,
Raymondi
There is no charge that will automatically happen.  Phone calls will simply stop working. The long distance minute add-ons can be used to add more minutes to your account, as strange as they may sound.  This is something that Public Mobile strictly allows for the $10/50 minute and $15/100 minute plans.  You do need to purchase the long distance add-on before you can use the phone for calls again after running out of that 50 minutes.
geopublic
Thanks guys,
Raymondi
@RaymondiIf you exceed your minutes your phone will stop working. PM is prepaid there aren't any extra charges. If you want more minutes you can buy an add-on to use in the future when you run out of minutes.
Note: Canadian based Add-ons never expire
Lieux
Thanks guys,
Raymondi
Public mobile is prepaid. You will never be overcharged. You pay just for what you have.
