Friday
Hi all,
Happy New Year. I have taken a USA Canada plan and wondering if roaming are extra charges or included in the plan? It says I can use the plan in US or Canada the same way which makes me think I don't need roaming?
yesterday
yesterday
Thank you so much! This plan is awesome 😎
Friday
@Moana22 You are correct, with that plan there are no extra charges. You do need to turn on data roaming in your phone settings.
Friday
HI @Moana22
yes, with the Canada-USA plan, no more roaming addon needed, all included in the plan.
So, you will use your service in US like you are home. Just make sure you turn on Mobile roaming data, and make sure your phone connects to T-Mobile, AT&T or Verizon. If it does not connect automatically, then try manual connect to all 3 networks and test
