change email
tstenner
I want to change my email address.
2 REPLIES 2
HI @tstenner   if you want to change email used in Community here, you can do it yourself here:
https://productioncommunity.publicmobile.ca/t5/user/myprofilepage/tab/personal-profile
But if you want to change the My Account email, you will need to open ticket with PM CS agent:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing :Change username
then Click " Forgot Self-Serve Email"
next Click "Contact Us"
finally Click "Click here to submit a ticket"
Yummy
You have to contact agent to do that for you. You cannot change it yourself.
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
