07-15-2023 12:00 PM - last edited on 07-23-2023 07:14 PM by Dunkman
Hello all , My wife has a motto g phone, she has 3g, i would like to change it to 5g, i checked her network settings and it only show Lte and 3g.My question is, do i need a new sim card? or when i subscribe to 5g will it automatically change to 5g, ant input would be appreciated. Thanks
07-15-2023 01:14 PM - edited 07-15-2023 01:14 PM
If your wife has the Moto G Play then it won’t work because it only 3G and 4G/LTE but if it is a Moto G 5G Stylus then you can connect to 5G.
In this case, all you need to do is to switch to a 5G plan and set the cellular settings on Moto to 5G or leave it on Automatic.
07-15-2023 12:39 PM
All those 3G/4G/5G plan are just speed
If your Moto G does not have 5G , you can still use it to access PM's 5G plan. Just make sure your network is set to 4G or LTE or Automatic
In terms of the speed, if you have the 5G plan (5G speed plan to be precise), you will be connecting at a higher speed than the 4G speed plans give you. So, instead of 100Mbps on 4G speed plan, you likely can get up to 150Mbps
07-15-2023 12:29 PM
All plans have 5G access, even the so called "3G" plans. If the Moto phone isn't showing 5G now, it is because of the phone software and changing to a "5G" plan won't make a difference other than peak speeds.
07-15-2023 12:07 PM
You do not need new SIM to change to 5G.
Even if you change to 5G your phone might show only LTE. Only way to confirm 5G is looking at your account and doing speed test before and after change.
