08-11-2021 08:03 PM - edited 01-06-2022 03:06 AM
08-11-2021 10:30 PM - edited 08-11-2021 10:30 PM
Hello @jin2021 ,
This area is serviceable.
If you just ported your phone number from another cell provider it could take a few hours to complete the port.
Using the other cell provider's SIM you should be still receiving calls on it, until the port completes.
If you ported from a landline it could take up to 7 days to complete.
Make sure you do not cancel your previous provider's services.
Incoming calls are usually the last to port over.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
If you have not received the SMS text to transfer your number from the previous provider, initiate the request again by clicking here:
Link to contact Customer Support Agents (CSA) for porting to Public Mobile
If this is not a new activation or transfer of a number from another provider check for outages in your area: https://www.telus.com/en/on/outages
or https://downdetector.ca/status/telus/map/
In the meantime, do one or more of the below:
08-11-2021 09:14 PM
@jin2021 are you new to PM ? or you have been with PM long and signal just go weak lately?
You are in a popular area in Toronto and I honestly think there are enough Bell signal in the area. You are mainly covered by two Bell towers, one on Finch between Don Mills and the other one by Don mills and Steeles. It might be a bit tickier if you are closer to Leslie and McNichol because of the valley.
What kind of phone do you have? Something North American model or something from oversea? Do you have problem with just Data ? Just Voice or both?
08-11-2021 08:45 PM
Are you porting in your phone number? If so did you reply YES to the porting authorization text from your former provider within 90 minutes of receiving it? If you didn't then you must renitiate your port request thru customer support or call the telus porting department with your old account #.
08-11-2021 08:21 PM
@jin2021 wrote:can not get phone call
Only one way to solve your issue , explanation to Customer Support Agent by CS_Agent,
and the are nice service Team the will help you 100%.
you Have To Submit a Ticket To Customer Support Agent by CS_Agent,
Here’s how to contact Customer Support Agent by CS_Agent,
Good Luck
08-11-2021 08:18 PM
08-11-2021 08:07 PM
can you try it selecting the network to "3G ONLY"
for iPhone visit Here
or Here
for android visit Here ,
if you still not working do one thing Make sure your phone is off before removing your SIM card,
and do rebooting your phone take your SIM card out and waiting for a 2 minute and put it back and turn on -This one is quick and simple.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
or can you do try reseat the SIM card
1. power off your device
2. take out the SIM card,
3. wipe it clean SIM card,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone means to turn off your phone and turn it back on again.
08-11-2021 08:06 PM
My cell phone can not receive phone call in M2H 1M8 area
