cant use phone
11-16-2022 02:08 PM
11-16-2022 05:22 PM
Gunna have to fork out some more $$ or use free wifi somewhere like Tim's...
11-16-2022 02:14 PM
1. Buy data add-on
2. Renew your plan Now
3. Upgrade to plan with more data
11-16-2022 02:11 PM
You can buy extra data add-on if you just short of a little bit of data before next renewal
If you want more data, you can open ticket with PM CS agent and ask them for an early renewal. Or you can login to My Account and make a plan change to another plan, must be different from your current plan
So, you have access to My Account? if you forgotten the login , you can open ticket with CS agent and they can help
At https://publicmobile.ca/chatbot.
First type Forgot Login,
11-16-2022 02:10 PM
Can you call in or out? Text in or out? The lack of data shouldn't affect those. Unless you're using an iphone and your imessage settings require the internet. But you can change those settings to make imessage work like standard SMS texting.
11-16-2022 02:10 PM
@cflem2112 , you have a couple of choices, either buy a data add-on to bridge to the next renewal or perform an immediate renewal and maybe with a plan that has more data.
