02-28-2019 08:01 PM - edited 01-05-2022 03:32 AM
I tried to transfer my speakout phone numbers to public mobile today but it did not work.
How could I do? Could I change try a new phone number and activate again?
Diana
02-28-2019 09:41 PM
@dianawong wrote:I tried to transfer my speakout phone numbers to public mobile today but it did not work.
Diana
@dianawong I ported out from Speakout two months ago with no problems. Make sure you had an active (with money still in the Speakout account) number. My port took about 2 hours - after about 4 attempts. As mentioned before, try incognito mode if you don't succeed first. I had to wait a full hour before my last attempt and then it went through.
What specifically did it say when attempting the port? Also check to see if your credit card was charged (mine was not until fourth and final attempt).
02-28-2019 09:32 PM
@dianawong wrote:I put the public mobile into my phone and found that there is no service provided. But when I put into my old speakout sim card, I found that it shows the speakout name. Did this means the activation is not completed?
Diana
Yes, there is a problem. It means activation did not work or your phone not compatible.
The Public sim should already be working.
How old is your phone? What model?
02-28-2019 08:22 PM
Yes...you will have to wait the moderator for completing it...
02-28-2019 08:21 PM
Diana
02-28-2019 08:13 PM
I have find this thread about porting from speakout... @dianawong
https://productioncommunity.publicmobile.ca/t5/Discussions/7-11-Speakout-PIN/m-p/289690
If you have too much trouble you can ask help from the moderator here...
Waiting time few hours to 2 days...
02-28-2019 08:13 PM
Diana
Do not try to change your number. It will only make things worse and complicate things.
Get your Speakout phone's IMEI and Speakout account PIN and send private message to Public Mobile moderator_tram. They will try it again.
02-28-2019 08:12 PM
