11-12-2017 08:40 PM - edited 01-04-2022 02:56 PM
hello,
I am looking for some help. I have recently ported and now I cannot receive incoming calls.
I can receive texts, and I call out/send texts, the only thing I cannot do is receive calls.
How can I fix this?
10-15-2019 12:06 PM
Send a private message to a moderator.
10-15-2019 11:59 AM
After 24 hours of porting an existing number from Bell prepaid, the new cell phone can not receive incoming calls. Outgoing and text messages work, but incoming still ring on old phone.
How can I fix this, since the ticket request box won't submit and filling in all the boxes repeatedly, turning off ad blockers, reboot, re-login?
09-11-2018 03:37 PM
@HeatherHowe FYI: you are pposting to a thread that is a year old. Look in the upper right of any post to will see the time stamp.
09-11-2018 03:30 PM
Just had the same problem. If you message a moderator, they will take care of it almost instantly for you 😊
11-14-2017 10:06 AM
Hi all...overnight all systems seem to be working for me. Thank-you for all the help, you guys are fantastic!
11-14-2017 09:15 AM
Good morning @kzuzek,
thank you for getting in touch with us!
If you require any assistance with your port request, please reach out to us via private message. We'll be more than happy to help out!
Cheers,
Mary
11-13-2017 11:39 PM
@kzuzek wrote:Still not working, message is that the 'number is unassigned'.
feeling nervous 😞
Are you porting from a mobile, landline, or VOIP? Mobiles are usually fine within a few hours (sometimes a little longer), but the other two can take a few days. I wouldn't stress about it tonight. It will probably be fine by morning, and if not the Mod Team will be able to sort you out.
11-13-2017 11:28 PM
feeling nervous 😞
11-13-2017 10:26 PM
Hi @kzuzek,
Give it a few more hours, if it still does not work by morning, send a message to the Moderators and they will be able to help you push the port through.
11-13-2017 10:25 PM
@kzuzek wrote:I'm having the same problem, just joined about 1/2 hour ago, hopefully will work in the morning!
Posted that an hour ago, guessing everything is running fine now? Porting a number usually takes an hour or two.
11-13-2017 09:20 PM
11-12-2017 11:40 PM
Are you porting a mobile, landline, or VOIP number? Mobile is pretty quick but the other two can take a few days.
11-12-2017 09:06 PM
I think you are still in the porting process and it hasn't been completed yet.
Please give it a couple of hours and everything should be ok.
11-12-2017 08:51 PM
if/when you message the mods make sure you give them your account name (as on bill) and account number
Contact the Moderator_Team by clicking here.
In your message include:
- account email address
- PM phone number
- explanation of what is happening or a link to this thread
- if its a porting issue include your sim number, old account name and account number
11-12-2017 08:43 PM
Thank you!
11-12-2017 08:41 PM
Hi @nicoleleeparker,
When did you port your number over to Public Mobile? If it was within the past few hours, give it some more time.
If it has been more than 24 hours, I would suggest messaging the Moderators using the below link to let them know your porting got stuck:
