My Account Login Error
jon7888
Is there a problem with the My Account login? I have been getting the same error all day.
Oh no!
It looks like something went wrong, but don’t panic.
Log out and then log back in again to continue. Or return to the Login Page
sley
I'm able to login but when I go to view my plan details I am getting the same error as well.
Shazia_K
Retraité / Retired
Retraité / Retired
@William,
I have received your private message, I will need to send a technical ticket for this.
I will send you a reply once I have a resolution for you.
Thank you for your patience !
Shazia
William
same here
Shazia_K
Retraité / Retired
Retraité / Retired
Hello @jon7888,
I'm sorry about this,
Can you send me a private message with your Public Mobile phone number?
Thanks,
Shazia
manelgm
Others are also having this problem it seems: http://productioncommunity.publicmobile.ca/t5/Self-Serve/Self-Serve-is-down/m-p/61504
Message a mod for assitance @Shazia_K @Mary_M
