05-26-2023 04:40 PM
Hi, I just bought a data package. It hasn't been used. You instituted changes that it now expires, even though you did not make that clear. I'd like to return the package. Your entire service is getting worse and worse. Thanks
05-26-2023 08:02 PM
@OMster your post should be directed to a CS rep. You have posted this to a customer community board. We are all customers.
05-26-2023 04:45 PM
@OMster Have to agree regarding the change to the data add-on. I think for most it's become too expensive unless they need data for an emergency, I know I'll hold off on buying it at the current price/short expiry period for it unless I absolutely need it.
You can submit a ticket to customer support and they may give an account credit if it's not been used although there's no guarantees as this is a prepaid service.
05-26-2023 04:42 PM
@OMster Yes it does expire now unfortunately , you can ask support nicely and they maybe able to reverse it for you
05-26-2023 04:41 PM
@OMster PM is a prepaid provider and generally don't provide refund. But you can try by opening ticket with support
