US roaming add-on data talk text
05-10-2024 11:20 AM
I have a 3G subscription with Public Mobile. If I purchase a US add-on for data, talk, text will these work in the states (NYC)? Does the "3G shutdown" of 2022 interrupt service with my 3G subscription?
Add-Ons
05-10-2024 11:23 AM
@ravedave It depends on your phone, which has to be VoLTE enabled by PM to work for voice calls in the USA since the 3G shutdown. What phone do you have?
05-10-2024 11:21 AM
yes, it will work. You have a 3G plan now, but actually that is a 3G speed plan, which means you can use 4G or even 5G network but just with slower speed
so, yes, you can buy roaming and can use full service in US.
