can't send or receive pictures
JackieHovan
Hi, I reset my phone to factory and I can not send or receive pictures in my text messages. Thanks for any help.
Jackie
9 REPLIES 9
JackieHovan
Thank you so much, it worked using the first option for APN type. 😊
@JackieHovan let us know of you have trouble update or saving the APN settings,  we have workarounds:)
@JackieHovan try to Reset All Network and see if it gives the correct APN
if not, try to either add a new PM APN profile or update and make change to an existing one.  This is the full APN settings
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
@JackieHovan
your apn is incorrect... are you able to delete those apn? delete them all if you can and then reset your network settings
sp.mb.com is what your looking for. what's the make and model of the device?
JackieHovan
Data is on,
JackieHovan
No luck, Do I have to change everyone of the listed access points? Screen shot attention.
Yummy
If you are using native texting app, in order to send/receive pics DATA has to be on even though send/receive will not use your data allowance.
JackieHovan
Thanks, I'll check
JK8
@JackieHovan
Make sure cellular data is on and your apn settings are correct.
https://apn-canada.gishan.net/en
