05-27-2019 07:57 PM - edited 01-05-2022 05:07 AM
Hi. My public mobile phone (my sons), iphone 7, cannot recieve texts from any other phone, including my iphone. He can only recieve when he is on wifi. Sending works perfectly.
I have tried some of the suggestions I found on these forums (i.e. report lost then found, remove SIM, restart phone, etc.). So far nothing has worked. I'm really at a loss now. Everything else on the phone, i.e. calling in and out + recieving texts are fine.
I have iMessage set to on and send as SMS set as well (although sending is not the problem).
I believe this could possibly have been happening since I started my public mobile plan a few months ago, but I didn't think anything of it because I had a basic send/recieve plan and thought I just ran out.. Now I have unlimited, so clearly thats not the case. I would appreciate any help.
05-27-2019 08:55 PM
I swapped two SIM cards (one pm and one bell) and was able to receive texts with wifi and cellular off on the both phones. The. When I put the Pm SIM card back into the original phone and tried it again, it worked!!!! Seems like Something reset.
thanks for your help with this!!
05-27-2019 08:46 PM
@kyleb Have you recently purchased a US Roaming addon for that sim? If yes, that would explain not being able to receive texts. The condition usually resolves itself within 24 hours.
05-27-2019 08:37 PM
Check you LTE settings if they're set on voice and data that could be your problem... Set it to data only
05-27-2019 08:30 PM
Can you try the SIM card in another phone to determine whether it is a hardware issue versus Public mobile service issue?
05-27-2019 08:28 PM
How about throwing his sim in a different phone just to see if it starts going?
05-27-2019 08:23 PM
Hi Mayor. Thanks for the quick reply.
I have have both of those set. Send/receive from my phone number only and send as sms checked.
And yes yes I have data as well but tried turning cellular on/off as well as wifi on/off to see if that would work.
I can send with cellular off and iMessage off and wifi off and still send successfully but other than wifi I can’t receive. Thanks for your help!!
05-27-2019 08:08 PM
Hi There - have you tried a network settings reset?
That might get you going again...
05-27-2019 08:07 PM
Does your PM plan have data? iMessage sometimes uses data if not on Wifi.
In your iMessage setting, you can use either your apple ID or phone number
