can not get into account
hdunnell
I am using my wifes account to connect. On my account the 6 digit security code never comes.
2 REPLIES 2
Meow
If you did not receive or cannot receive your 2FA code by SMS - Click on: ‘Didn’t get a code’ and you will get more options. Chose email.
SourDude1234
Hi @hdunnell
Click "didn't get the code" at the bottom of the 6 boxes, then select "Send via email". Check your email for the 6 digit code.
