porting my old number to PM
11-16-2023 02:35 PM - edited 11-16-2023 02:40 PM
11-16-2023 02:45 PM
@pok wrote:Hi, our old number still have not been ported to PM, this is the info we got from the service provider to port out. I have the info and will give it to you in private, I'm not sure if this is private message or a forum post. Thanks
Plese note that HTideGnow does not work Public Mobile (neither do I), so please do not provide any infromation about your account to anyone but the user CS_Agent. CS_Agent can be contacted through: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
11-16-2023 02:40 PM
ok done, thanks
11-16-2023 02:36 PM
HI @pok
update your post to remove your phone number. You are posted that in the public forum
for porting problem, call the porting support team. I will message you the phone number. Check Community inbox
