03-29-2025 11:16 PM - edited 03-29-2025 11:17 PM
@OP: did you ever get this resolved?
Just ported over a family member's number from Fido earlier today (~3ish hours ago). Phone calls in/out are fine, data works as expected. But SMS (including the ones from Eversafe) are not coming in, nor going out. Oddly enough- I sent a couple test messages and my phone shows them as delivered, so I can only assume there's some kinda network delay on Fido's end for routing? Sent a message to support anyways in case there's anything they can jog it on their end. Port approval was given, and it all went really smooth in <10mins other than SMS. Once Port apporval the Fido SIM died in a matter of minutes so we removed it.
03-30-2025 06:45 AM
Yup, it managed to resolve itself overnight. For some reason my response to the port out text to fido didn't go through the first time
03-30-2025 02:14 AM
can be a problem with the messaging app. Is that Android? If so, try backing up important text first. Then uninstall Google Message and reboot phone. Last, reinstall/update Google Message from Google Play Store
