broke sim card mid activation
robertbrant87
hello, i purchased public then when putting a sim card i bought from amazon it snapped in half, i cant access the eversafe thing because it asks me to confirm full access with the phone number.. which i cant do because well. the sim card got snapped!
please help me, there is no option to send a email code
HALIMACS
This may sound crazy, @robertbrant87 , but you're certain the outer adapters simply haven't dislodged from the SIM card itself, are you?   If they have, simply snap them back on if you need a micro or standard size, and not the smallest nano sized.
Grinch
Keep in mind after all is done, try for a refund.
Dunkman
@robertbrant87
Is there an option to resend code?  If you request resend code, it will sometimes offer email verification code.
If not, then you will need to contact customer service agent.
Send a private message to CSA through the following link :
