been overcharged
LARY
upgraded to a better plan but been overcharged
Yummy
Please define and explain 'overcharged'
@LARY this was normal as you used Change Now option.
PM is a prepaid provider and do not provide partial refund if you change plan early.   There were actually warning before you confirm the change with Change Now.  You should have used Change on Renewal to schedule the change at the end of the cycle to avoid that
@LARY  Unfortunately there’s nothing support can do as it’s pre paid it’s why it’s always advised to change plan for next renewal when you see a better plan being offered
Change plan in 3 easy clicks
Once you find plan you want be sure to (change on renewal )So you don’t lose money on current cycle
LARY
i had a plan but upgraded 2 days after paying for the month
@LARY Did you change plan right away and not for next renewal ? If so then PM is right in charging you for the new plan upfront as it’s pre paid service . If that’s not the case and you changed it for renewal then submit ticket with support  to investigate
send a  private message   To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
