automatic number anouncement ANAC
CellphoneuserPM
Does anyone know the ANAC number that you can call to tell you your phone number? This is a number you call and an automated voice tells you your n\phone number.
7 REPLIES 7
CellphoneuserPM
Can anyone provide a working ANAC number for Ontario ?
@hTideGnow
Telus high speed internet running on copper requires 2 telephone numbers. Perhaps the tech needs to know what 2 wires are what number??
Are you trying to figure out what your phone number is set to @CellphoneuserPM ?
Can you text yourself an SMS and then go to the details of the sender in the messages app. This will show you the number.
CellphoneuserPM
If you call the service in ontario it does not work it says 6 UT1 not in service.
Is there any Ontario ANAC number that works ?
Thanks all , learned another thing today
But what is the purpose to this now?  I understand it might be helpful back then for landlines and no call display
Now, your phone app, sim status will show you this.  Call another number and call display also has the info
ShawnC13
@CellphoneuserPM
I haven't test this specifically on Public Mobile but try dialing an area code followed by 958-2580.
