Unused roaming data
angelawd
I just returned back from the states after 4 days, so I still have 6 days left on my US Roaming 1g that I purchased. Can I use that as part of my monthly data now back in Canada until the 10 days is up, or is that only for in the US?
JL9
Unfortunately not, if you use another roaming Add on you can go crazy with the data when you know you are wrapping up your trip and have data available
@angelawd
You can only use up the remain US Roaming if you reside or at a border town.
Timer
@angelawd
no you can't use those US roaming , in canada.
@angelawd   Sorry, roaming data is strictly to be used when you are in US.    you cannot use the remaining data when you are back in Canada 😞
