03-01-2024 07:29 PM
i just switched to the PM esim plan from bell this afternoon. i somehow lost my number and it is deactivated. and now all streams of communication (text, call, facetime) are through my email. and with my email i cannot call anyone. my number disappeqred and my contact now displays my email. please help !
03-01-2024 10:52 PM
@dwh1 That happened to me after an ios update and had to go in to iMessage settings Send and Receive and re-select the phone number. Somehow it had got unchecked and only email was checked so I couldn't message anyone to their phone number.
03-01-2024 07:50 PM
@wnops @I’ve had iMessage disable sending from the phone number - os opposed to the email - when I port. I think it’s a glitch in iOS respond to sim changes. Fortunately you just have to go into Settings/Messages/Send & Receive and reenable it.
I’m not sure this is all that is going in for you, but it should help.
03-01-2024 07:42 PM
@wnops - If it is asking you to remove your old phone number from Bell before porting, do so, then it'll ask you to add your same number back after porting in to PM to FaceTime & iMessage.
If you lost it on your Settings > Phone > Phone Number & your number isn't there, then contact CS_Agent, if you can see it, but cannot add it back to iMessage & FaceTime, contact Apple Support Here!
