mms not working on samsung ace
Ashley86
@Ashley86  If the phone is older then 2017 it I’m not be supported anymore for MMS what phone you have and does it have the latest OS update
@Ashley86
Samsung ace was released in 2011 and is too old, and affected by this announcement:
https://productioncommunity.publicmobile.ca/t5/Announcements/Picture-and-Group-Messaging-End-Date-Fe...
there is a very slight chance it will work, but you can try to click Reset All networks or Reset network settings to get the latest APN
Also, you can make a manual update, here are the old and new settings
Old settings:
APN: sp.mb.com
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN Type: default,supl,mms
                             or        default,mms,agps,supl,fota,hipri
New Settings:
APN: sp.mb.com
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
MCC: 302
MNC: 220
Ashley86
