01-11-2022 05:57 PM - last edited on 01-11-2022 09:23 PM by Dunkman
Tried to change my phone # with current activated bell #. Says this # can't be used. It says that because I'm using it on my bell act. I assume. Tried talking to people at telus (# providied here by a couple people) Telus rep says they can't port to my PM sim as they have nothing to do with Public Mobile.
01-11-2022 10:25 PM - edited 01-11-2022 10:31 PM
@badgolfshot wrote:Thanks. I guess it's not transferable as I live 100 from the nearest PM city. Same area code different prefex
As for what Telus customer care/porting team told you about them having nothing to do wth Public Mobile, they are correct that it's Public Mobile who needs to initiate the porting of the phone number to Public Mobile, but the Telus customer care person should have mentioned that Telus Communications is the parent company of Public Mobile. They are also able to troublleshoot open number porting requests to Public Mobile. They shouldn't be called to start a number porting request.
The Bell phone number doesn't need to be specifically from a city in the available phone number/city list in the Public Mobile account, but it does need to be from a city that Telus Mobility has a block of phone numbers for.
01-11-2022 07:04 PM
@badgolfshot : Never mind the above post. They have a distinct inability to read.
01-11-2022 07:00 PM
Eligibility Check if your existing number is eligible to move visit Here link
if you stuck with Transferring your old Phone Number, or is not complete processing
Here’s how to contact Customer Support Agent by CS_Agent,
01-11-2022 06:35 PM
Yeah it's a weird thing. I only learned that it was a thing, here. So you have some decisions to make.
01-11-2022 06:29 PM
01-11-2022 06:09 PM
@badgolfshot : Can you check here to see if your number can be moved over to Telus/Koodo/PM. The source account needs to be active. When you do get to port it over then leave the old SIM in until you get a confirmation text to confirm.
