08-31-2024 04:37 PM
08-31-2024 08:04 PM
I thought you ported to Fido from your previous post.
Just talk to Fido about this issue.
08-31-2024 06:20 PM
Did you port in your number during activation? If yes, did you get a text to authorize the port in request? If you don't do this within 90 mins, your number won't port in. You must contact PM CS_Agent to get it resolved.
08-31-2024 04:38 PM
hi @RUSTY-STEELE your text maybe just iMessage
so, ask support agent to check if your activation was done correctly
Message them
