account number
04-29-2020 02:56 PM - edited 01-05-2022 10:35 AM
I need to set up a new password,
how can I sign in without having text to receive a verification?
Joining Public
04-29-2020 06:08 PM
@SaraG wrote:I need to set up a new password,
contact the moderators directly through private message here
04-29-2020 04:57 PM
@SaraG do you still need help? Or did you use the link above to contact the moderators? Stay safe.
04-29-2020 04:10 PM
I forgot my password and my plan has no text to receive a verification code.
04-29-2020 03:30 PM
@SaraG wrote:No,
the problem is that my plan has talk only and NO TEXT
@SaraG Send a private message to the moderators here https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437, but this alternative method may have longer response time.
Once you regain access to your account, I suggest you look more closely at the current plans. I suspect you are paying about $25/30 days. The current $25 plan is unlimited Canada wide calling and world wide texting; PLUS you would be eligible for rewards, which in your case should be around $6/month including autopay. The $15 plan with $5 500 minute add-on would likely suffice as well and be $10 cheaper.
04-29-2020 03:05 PM - edited 04-29-2020 03:07 PM
It is not clear whether you forgot your pw or you need to change your exisiting pw. If you need to change your pw then you can do this in self service.
@SaraG You must be on a Grandfathered plan that dosent include text. What plan are you on. You should be able to receive Txt Messages. Especially if they are from Public Mobile. Have you tried the reset? Does it do anything?
04-29-2020 03:04 PM
No,
04-29-2020 03:04 PM
Have you tried a password reset? If that isn't working for you then send a message to moderators via SIMon here: https://publicmobile.ca.ada.support/chat/
The email from moderators will have two hour window so make sure to check all your messages often, otherwise you will need another password reset request.
04-29-2020 03:02 PM - edited 04-29-2020 03:04 PM
@SaraG Ok let me clarify things here. So you are an existing PM customer that needs to rest their password. Now during the password reset it sent you a text verification. But you never received it right? If thats the case then try the reset again. Or are you on a old limited text plan and you ran out of text for the month. If you did you still should be able to receive text messages. Especially if its from Public Mobile themselves.
