E sim
LisalynnI
Need a esim for new device Moto G play 2024 but when I select it under my account it is not allowing me to
@LisalynnI wrote:
Funny thing I did confirm with Best Buy that it was ESim compatible.
Unfortunately my Samsung 24 Ultra got ran over and decided to purchase the cheapest phone available since I will be purchasing the an Iphone when they release the newest one. Seemed senseless to get the 16 since the 17 will be released shortly.
I will have to see if any private cellphone stores in my area have any sim cards available I guess.
I'd return the phone and look at the Motorola G 5G. It's roughly the same price and it supports eSIM.
Buy the sim from Amazon for just $5
https://www.amazon.ca/gp/product/B06X9ZGDWG/
Or you can buy locally from Telus or Koodo or Mobile Klink for $10
LisalynnI
@LisalynnI
You will need to purchase a SIM as The Moto G Play 2024 is not eSIM compatible.
https://m.gsmarena.com/motorola_moto_g_play_(2024)-ampp-12798.php
https://m.gsmarena.com/motorola_moto_g_play_(2024)-ampp-12798.phpIn
In the future confirm with the seller is the phone is eSIM compatible before purchasing.
Chalupa_Batman
I do not believe the Motorola G Play 2024 supports eSIM. You may wish to check your manual first before attempting to make this purchase.
@LisalynnI you need to use the app to buy
Once logged in, Click Account from the bottom, then click Purchase SIM Card and select eSIM
