07-03-2023 03:29 PM
I lost my phone, and have not done the set up.
For now, after typing my e-mail and password, I was asked for a code which was sent only to my phone, which I lost.
Need help to access my account.
Thank you.
07-05-2023 05:49 PM
Thank you, appreciated your help.
07-05-2023 05:49 PM
Thank you, appreciated your comment.
07-05-2023 05:49 PM
Thank you! Appreciated your comment.
07-05-2023 10:42 AM
Exactly what I am experiencing for the past 2 weeks of incomplete activation. Case with CS agent has gone from 1. workarounds. 2. PM engineer confirm client problem fixed. 3. Fix allowed one-time OTP challenge which expired. 4. Activation incomplete as in day 1. CS agent suggest same work around to repeat. sheesh
07-03-2023 03:38 PM
When that happened to me I never got that option. It sent the code my phone 8 times. That was when I was switching to Public Mobile. With that only a customer service agent can help.
07-03-2023 03:30 PM
@Yebo Try hitting resend a few times . You may get option to send code to email Instead . If not please get help from support to fix
message support directly
while your already here and logged in the community you can send a private message To CS_Agents click
07-03-2023 03:30 PM
If you have not created an EverSafe id yet, you won't be able complete the part to link your My Account with the EverSafe ID, that needs a working phone with a working PM sim using SMS. (Sending the code to email would not be a choice until EverSafe id is fully setup)
Try these workarounds, it could bypass the SMS in linking My Account with EverSafe ID
If none of those workarounds helps, please open ticket with support by direct message here:
