lost phone - cant login
theform
I lost my phone. It now asking me to verify my phone account with a verification code texted to my phone. I dont have the phone so i do not get a code. What can i do? I started a new account with a new phone, so i am good there. Now i just want to cancel my old phone. How do i cancel it if i dont get access to the text code?
theform
unfortunately, there is no option to verify for email as the text verification is the second stage after I have already verified via email code. I have opened a Private Message to an agent and hope they can help, as you suggest. TY.
theform
The issue is that it prompts you for the email verifiction, then once that is verified, it prompts for the text verification code. so it wants both codes and doesnt have a button or option for anything else. thank you for your advice.
HI @theform
did you try click Didn't receive code at the verification step?, it will then give you the Send email option
if that does not work, then you will have to ask support agent to help.    you can submit  ticket by direct message:
@theform  Can try and gap “didn’t get code “ and you might get option to send code to email instead of not get support to report phone lost/ stolen for you until you get new phone / SIM card
send  a  private message   To CS_Agent
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
adding once you have new phone and SIM card support can sim swap the number for you and you will keep same phone number and plan @theform
Find SIM card Find a store near to you | Public Mobile
Amazon
Public Mobile Prepaid SIM Prepaid Phone - (Universal/SmartPhones), Packaging May Vary : Amazon.ca: E...
