07-05-2023 05:14 PM
07-05-2023 05:58 PM - edited 07-05-2023 05:59 PM
try to uninstall and reinstall app and try again
And if you have another phone, you can install the app there and try to finish the activation. Once activated, you don't really need the app. And remember to scan QR code later to complete the eSIM installation and not to use automatic install if you are finishing it off on another phone
Again, 8f nothing works, PM support are your friends, message them
07-05-2023 05:56 PM
I have tried force closing the app many times ... same thing happens each time ... app freezes
07-05-2023 05:45 PM
@Bwb896 can you force close the app, clear data and relaunch app to continue the activation?
if that does not work, open ticket with support
07-05-2023 05:31 PM
there is no QR code in welcome email
when i click on "Activate" in the App .. then i enter my existing Cell # to Transfer .... then click Continue and the App freezes
07-05-2023 05:16 PM
Did you get to the eSIM installation step? Either the app will ask for your permission to do it for you automatically, or you will get a QR code to install yourself.
If you missed the step, there is a QR code in your Welcome email. Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone
Once you installed the eSIM profile, (or If you got passed that step), try to reboot your phone once.
If it still does not connect and if you have any active sim on the phone , disable them (eSIM/Physica sim) or remove the physical sim. Then click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetoosh connections, but you just need to add them back after)
if it still does not work, please open ticket with PM support
07-05-2023 05:15 PM
@Bwb896 Check your welcome email for the QR code on a computer and scan it with your phone
