Your first community reward?
Devcon
What tasks need to be completed in order for you to receive your first community reward? Are the reward tied and reflected by the badges you receive?
@Devcon
Looks like you have been on PM over 2 years.
You will receive a Community reward when you participate on this Community forum.
The dollar value credit amount will depend on the number of replies, bravos solved solutions.
JL9
They used to have badges that will tell you what community reward you received but that has not been the case for awhile, you will just see it in your rewards. It doesn't take much to hit the first tier or 2 of rewards.
HI @Devcon  Welcome to the Community
But seems like you have joined some time and just decided to participate more for the Community reward?
The key here simply to Keep Participate.  Reply any posts that you think you can help.  Bravo other's good posts.  Usually , getting $1 or $2 is not too hard.  Come here once a week and reply and help should be able to get you some Community reward.  But getting $5, $10 or $15 would be a lot more involvement.
Good Luck and looking forward to see you a lot here
(Badge has nothing to do with reward.  Budget just try to make sure you feel good  🙂 )
Spudster
@Devcon
Basically, the process requires you to be responsive and respectful to questions posed by other members on this forum.
Give them helpful advice, be brief, and be specific to the question they’re asking.
If you receive lots of bravos and solutions, this will assist toward your community reward value.
No, the community rewards are not tied to the badges you receive, although eventually public mobile will start assigning badges to the level of community reward. This used to work for years but it has been challenged recently.
