Wrong add on purchase
Clara5K
Could an agent please contact me to change my add on rewards to the correct US plan?
@Clara5K
CS_Agent staff won’t contact you to change your reward to US Add-on.
PM is an online service & self-serve and you will need to contact them first by private messaging on your computer. They will reply back by pm.
As @hairbag1 noted, it will be quicker for you to login to your account and do it yourself.
hairbag1
@Clara5K
probly quicker to just get the add-on you need yourself, then ask CSA to credit your account for incorrect add-on cost.
@Clara5K  no worries just please message support for a credit
message support directly
  • while your already here and logged in the community you can send a private message   To CS_Agents click >>>here.<<<
