08-04-2022 12:35 PM
Hi,
I would like to change my current $15 plan to a $25 one and I wonder if my accumulated rewards ($4) will disappear if I do ?
Thanks
08-04-2022 02:26 PM
@Awres wrote:Thank you for replying but I just went ahead and upgraded my plan effective now instead of renewal date (Aug 7th) and I noticed my rewards which usually decrease my monthly by $4 were not applied. Should I report this as an issue or will it apply later ? 😞
Answered on your own thread:
08-04-2022 02:00 PM
08-04-2022 01:04 PM
Rewards along with add ons whether they are gifted, promotional or purchased are associated with the account not the plan. Promotional recurring bonuses of plan data or monthly plan discounts with a month counter or "unlimited" beside it will disappear if you change rate plans. But you are safe to schedule a change plan on next renewal.
It is advisable to manually top up your with your new plan amount to avoid the possible autopay glitch that only charges your card the old plan amount causing your renewal to fail due to insufficient funds.
08-04-2022 12:37 PM
Thank you !
08-04-2022 12:36 PM
No your rewards will not disappear when you upgrade your plan so go ahead.
