12-19-2020 12:12 AM - edited 01-05-2022 04:32 PM
Hi,
I want to downgrade my plan as I am not using enough of the 5GB I get. However I did recently get the holiday gift of 500 intl mins and 2GB of data - will I lose these if I downgrade?
12-19-2020 04:54 PM
I think the holiday 2GB data is an "add-on", which are independent of your mobile plans. Any add-on would continue to roll-over even if you switch plans, so I think that explains why the holiday 2GB still rolls over when you downgrade your plan!
12-19-2020 02:57 PM
Holiday gifts stay but I think some promos like the RBC rewards one from a while back go if you downgrade plans.
12-19-2020 12:36 AM - edited 12-19-2020 12:37 AM
@sophyc...
we have to work from home and limit our time outdoors so many of us are using wifi more often now, thanks to C19.
I've reduced my regular plan from $25 down to $15 without any loss of holiday gift data from this season or last season. The plan reduction and use of gift data/wifi is an efficient way to save some $$.
Always a good idea to keep your eye on any PM plan announcements though.
Happy Holidays 😷
12-19-2020 12:32 AM - edited 12-19-2020 12:35 AM
😇You are lucky😇
👉🏽You will not lose the free promos if you change plans👈🏽 and 🤞🏼promos and holiday add-ons data save for next holiday if you don't use it.
thanks👌🏽
12-19-2020 12:26 AM
You are lucky.. you got to keep the holiday gifts as long as you stay with PM 🙂
12-19-2020 12:14 AM - edited 12-19-2020 12:15 AM
@sophyc wrote:Hi,
No, you will not lose the free promos if you change plans. They remain on your account until consumed.
