Will I be able to receive SMS text messages while travelling outside the US/Canada
floflo86
Hi community,
I'm looking for information on whether or not a Public Mobile SIM works outside of Canada/US, as I can't find any information on this topic.
For example, let's say I'm travelling to France. Will I be able to receive SMS text messages and calls while in France? Or will my Public Mobile SIM not work altogether.
I know there are no add-ons for this, but there is also no information as to what happens when you travel on a Public Mobile SIM.
Any information would be appreciated 🙂
8 REPLIES 8
mh1983
@kselmak wrote:
@floflo86
Consider getting TextNow phone number and pass it around as your alternative number, it's totally free and you can receive/make calls and texts over WiFi or local data
This was already suggested 30 min before your post.
kselmak
@floflo86
gblackma
No @floflo86 PM will not work outside of Canada or the US. Try adding a voip app such as TextNow and use it over WiFi to make/ receive/ send  calls and texts anywhere there is WiFi available back to Canada. Stay safe.
Triguy
PM only has US roaming.  You can buy a local sim or use Gigsky.  If you have access to wifi then you could use apps like Textnow or WhatsApp.
hairbag1
Your PublicMobile features will not work outside of Canada. An Add-on will let it work in US...but nowhere else will work.
geopublic
@floflo86 wrote:
Hi community,
@floflo86  The answer is no it will not work. Public Mobile works in Canada and in the US if you purchase a US roaming add-on. Roaming to other countries is not possible.
 @floflo86
All services work only in Canada. There are roaming options only for the US. Nowhere else. The networks elsewhere will see you, but they'll ignore you.
popping
@floflo86 wrote:
Hi community,
PM does not have roaming add-on outside North America.
You need to purchase a local SIM card after you arrived at your destination.
If you are using WhatsApp to communicate with family and friends, you can still use it over WifFi or get a local SIM card.  With the local SIM, all you need is to update your WhatsApp account with the new local phone number.  Your family and friends can still communicate with you using WhatsApp without knowing your local phone number.
My family members uses WhatsApp exclusively in Canada and while traveling to communicate with family and friends.
