06-15-2022
10:11 AM
06-16-2022
12:45 AM
computergeek541
Hi everyone,
For almost 2 weeks Wi-fi has been disconnected.
I checked Settings numerous times, called my Internet Provider, went 3 times to Public Mobile sales booth, nothing has worked so far.
I got an email from Public Mobile about the use of 100% data, could it be the cause of Wi-fi disconnected?
Thanks.
06-15-2022 07:37 PM
Some phones will go directly to using cellular data if you lose a wifi connection. If this is your concern, check your phone settings or search this on youtube to make sure it doesn't continue.
06-15-2022 10:53 AM
It sounds like you are confusing data with WiFi, WiFi is your internet and if connected you won't be using any of your PM data, so since you are out of Data you can wait until your next renewal and get an add on if you really need it, or if you need it immediately, you can reach out to a CSA and request an immediate renewal
06-15-2022 10:46 AM
06-15-2022 10:31 AM - edited 06-15-2022 10:39 AM
06-15-2022 10:30 AM
Hi,
Will wait until the payment to see if reconnected with Wi-Fi.
Thanks
06-15-2022 10:27 AM
Under Data and adds-on, just minutes are listed no mention of data.
So just wait until the monthly payment and Wi-Fi would be reconnected?
Thanks again
06-15-2022 10:19 AM
If you have WiFi issues that is related to your phone or your home's router/modem. PM service does not affect your WiFi connection.
06-15-2022 10:14 AM - edited 06-15-2022 10:16 AM
@agl2005 hi wifi and your public data are 2 different things you can check in your self serve account under data and addons if you don't see a line for data then it is all used up
06-15-2022 10:13 AM
@agl2005- WiFi has nothing to do with your mobile data (being used up - or not).
06-15-2022 10:13 AM
Mobile data or cellular data is capped by your plan and any add-ons. Once all is used, it stops. Do you see any mentions of data under my data & add-ons on your account?
(wifi is not mobile/cellular data)
