05-30-2023 06:31 PM
05-30-2023 07:33 PM
There actually IS a contact number to assist with porting when there is a problem with porting a number from another provider.
I'll private message you the number. You can get it by checking my message under your private message box upper right (you'll see a number over the envelope to indicate there's a message)
I have to private message the number as PM does not 'like it' when members post it publicly on this forum.
05-30-2023 07:16 PM - edited 05-30-2023 07:16 PM
You might need a new phone number or can call your previous phone provider to make sure the phone is unlocked
05-30-2023 06:51 PM - last edited 2 weeks ago
the error " Invaid Phone Number - Please enter a valid Canadian phone number" is either because
If you are porting in from Koodo prepaid, you have to activate with a new number first. Once activation completed and you can make calls and recieve calls, then you will need to open ticket with PM support for a manual porting request.
if you are NOT porting in from Koodo prepaid but was re-attempting the activation a second time, you will have to open tickte with PM support and have them to clear up the earlier activation attempt. Please open ticket using Public Mobile Expert Messaging , Select Start a Chat to begin (You will need to use your current Community account to login to submit the ticket):
https://expert-messaging.publicmobile.ca/guest/pre-chat
**You'll get email/sms alert when agent replies. or monitor here: https://expert-messaging.publicmobile.ca/message-centre
05-30-2023 06:51 PM
Check to see if # can be ported
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do
05-30-2023 06:47 PM
05-30-2023 06:43 PM
Hi @Fccc Yes, a phone company without phone support. I know it sounds weird. But Support here is all online
Post your question and we can try to help
or you can submit ticket with CS agent and they will reply via Community inbox
05-30-2023 06:42 PM
05-30-2023 06:36 PM - edited 05-30-2023 06:37 PM
