Why haven't I received my 2 G data bonus text message yet?
Mmarquis
Today is December 19, way past December 15, and still no text message for the annual 2G free data. Anyone else didn't  receive their's yet? My wife got hers 2 weeks ago and we share the same last name.
11 REPLIES 11
dannycdee
Go to the menu (on the Public Mobile main website, not the community page), select Get Help. Then click on Chat with SIMon
@Mmarquis wrote:
That chatbot Simon is nowhere to be found. I am usually quite adept at these things but man oh man, i'm not so sure about this site.
@Mmarquis   you can follow this steps to open ticket on Chatbot.  Or you can also use Method 2 to direct message if you still have trouble with chatbot
Just open a ticket via Chatbot for PM Support :
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
Mmarquis
@GeorgeannaNg   as advised on your other post, try to send YES2 to short code 4211 and it can be added immediately.
If that does not work, open ticket with PM Support and they will add it back for you
GeorgeannaNg
My wife experienced same problem as you (No Holiday 2 GB Bonus and 500 international long-distance call minutes)
@Mmarquis
Looks like that you'll have to get a Customer Support Agent to add those holiday gifts to your account manually.
Use the Chatbot Simon to get a service ticket started first.
Mmarquis
How do you do that? I dont see that option anywher.
Mmarquis
I just did and the reply is ''Looks like you are not eligible for this offer........''   I have been with PM for 3 years now and always received it.
dannycdee
I think you should check with the moderators here because I did receive the message already.
You will need to submit a ticket through the community agent
walker1
@Mmarquis
Try sending YES2 to 4911
If that doesn't work then you'll have to get a Customer Support Agent to add those holiday gifts to your account manually.
You'll find the link at the bottom of this page.
