03-06-2023 03:45 PM - last edited on 03-08-2023 12:37 AM by Dunkman
When signing up for public mobile, I used a referral code from a friend in order receive rewards, however it has been been around two weeks and there is still no sign of the any rewards received. Any help would be much appreciated.
03-06-2023 05:26 PM
You should have a $10 credit in your account which will apply to your next bill.
Also check your friend to see if they gotten a text “Cha-Ching- You just added a RAF Reward”.
03-06-2023 03:49 PM
@kilo check your My Account to see if you see $10 showing as Available fund there, if so, you got it
If not, just open a ticket with PM support for them to add it back for you
Please open ticket with PM support using Chatbot:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
