03-06-2023 04:29 PM
03-06-2023 05:22 PM
Got a new number
03-06-2023 05:10 PM
Try:
If you are new here and were porting a number, did you reply "yes" to the port authorization text from the prior provider which would needed to have been done with your prior provider SIM card in your device?
If you are porting a number, and you did not respond to the text, I'll send you a number you can call to help with the porting.
Check your private messages by tapping the little envelope icon on the upper right.
03-06-2023 04:48 PM
@Scoobs75 are you new customer and asked porting old number here or you are customer for some time already?
03-06-2023 04:43 PM
I have the same issue
03-06-2023 04:32 PM
