12-30-2019 12:38 PM - edited 01-05-2022 08:47 AM
I just switched to public mobile and when I dial local numbers now I get the message at the beginning of the call saying it's completing my long distance call. The chatbot told me to try dialling +1 in front of the phone number, but why do I need to do this for local calls? I'm afraid I'm going to be charged a long distance fee.
01-02-2020 12:09 AM - edited 01-02-2020 12:11 AM
@susieliu97 wrote:...when I dial local numbers now I get the message at the beginning of the call saying it's completing my long distance call..
For whatever reason, Telus' network (which is also shared by Koodo & Public Mobile) thinks the number you are calling is not a local call from the cel tower your phone is currently using. Maybe you are in a borderline area with another local calling area, and your previous carrier (Bell,Rogers) had a tower in a slightly different location.
Regardless, as many others have already noted - it's safe to either wait out the annoucement , and then your call will go through, or prefix 1 to your phonebook entries without any worry of extra long distance charges to avoid the message entirely.
Cheers - N.
12-30-2019 02:10 PM
Adding a 1 in front of any 10 digit number whether local or long distance will work and won't turn it into a billable long distance call. Most of the numbers in my directory have a 1 in front of them to ensure it goes through quickly.
AE_Collector
12-30-2019 02:07 PM
I put +1 in front of all my numbers, especially in my contacts. Set it and forget it, I always say. No overage so nothing to worry about, regardless of where you are in Canada or where you are calling.
12-30-2019 01:44 PM
Regardless of the canned messages, this is a prepaid service and so there can never be any additional charges above and beyond those services that have been purchased already. I have a province wide calling plan. Whenever it dips into the long distance minutes add-on, I get the message about long distance charges being applied.
12-30-2019 01:33 PM
As far as i know, it won't charge any extra whether dial +1 or not as long as you are in Canada.
12-30-2019 01:06 PM
@hairbag1 wrote:All PM plans are Canada wide calling. You'll not be charged long distance rates for any calls within Canada.
If you run outta minutes your phone quits working until renewal.
@hairbag1not all PM plans are Canada wide calling. All currently offered plans are.
@susieliu97 when you signed up did you pick a new number? If the call would be a long distance call from a landline you are required to use a 1 first to dial it without the message. If this is a new number could if have an area code that is not local to the area you are in?
12-30-2019 12:58 PM
@susieliu97 wrote:I just switched to public mobile and when I dial local numbers now I get the message at the beginning of the call saying it's completing my long distance call. The chatbot told me to try dialling +1 in front of the phone number, but why do I need to do this for local calls? I'm afraid I'm going to be charged a long distance fee.
Don't worry. It is up to you whether or not to add +1 to any number. Calls will work anyway and won't cost extra fee.
12-30-2019 12:43 PM
You don't have to dial 1 if the message doesn't bother you
They won't charge you anything, there is no surcharge with public mobile, if the call goes through it's included
Welcome to public
12-30-2019 12:40 PM - edited 12-30-2019 01:17 PM
EDIT; all currently offered calling plans have Canada wide calling...as noted by @ShawnC13
