Not receiving calls while out of province
James48
I have a MB phone number. I'm currently in BC. When local numbers from BC try to call me they receive a message "We're sorry, your call cannot be completed as dialed, please call your operator for assistance."
This is with dialing 1 before the number. Just dialing the number without the 1 yields a message that a 1 needs to be dialed first.
I've tried restarting the phone and refreshing network connections.
If I dial a long distance operator ("00") and provide them the number the call goes through.
What's going on?
2 REPLIES 2
Chalupa_Batman
What's going on?
Hello @James48
Thank you for already sharing with us that you've rebooted your phone and reset your Network Settings. Do you have the Public Mobile app on your phone and have access to either data or WiFi? If so, log in and see what plan you have and, more importantly, it's paid up. A long shot, what phone are you currently using?
slusagm
Do you have only a provincial calling plan from years ago?  Check your My Account to confirm
If you have. Canada calling plan, try reboot phone and Reset Network Settings
Or ask PM to check Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
