09-24-2022 12:12 PM
Last month I bought a plan for travel to the US, and yet it didn't work when I was there. I had my cellular data and data roaming turned on, but couldn't make phone calls or access the internet unless I was on wifi. Does anyone know why it wouldn't have worked or how I can get support on this from Public Mobile and a refund too? I have to go to the US again next month and then Mexico, I need to be able to use my phone and would like to know what I did wrong, to ensure my plan will work.
09-25-2022 10:12 PM
Thank you, it seems like that is what I will have to do.
09-24-2022 03:02 PM
buy it prepaid US sim card from amazon has US and Mexico.
09-24-2022 12:26 PM
What make / model phone ?
09-24-2022 12:25 PM
Go into your network settings and select the network your prefer.
09-24-2022 12:23 PM
Thank you, not sure I know how to 'manually' connect? Do I just go into settings and then cellular and when I'm in the US, T-mobile will show up?
09-24-2022 12:21 PM
Ok, thanks very disappointing then, if they aren't working, they shouldn't be selling them.
09-24-2022 12:21 PM
I was successful in using the add-on in US by manually selecting T-Mobile as the network. I found it worked resonantly well in populated areas...not so much in rural areas of Washington state. Your results might vary.
For use in Mx, you'll need a local sim and cheap plan. I purchased a Telcel sim and had a comprehensive 30 day plan ...all for about $20. I could call most any Cdn and US number. It even works while your in Caanada.
09-24-2022 12:21 PM
Yes I was connecting to a US network and for Mexico I'd buy the Int'l plan, will that work or are you saying no Public Mobile plans work in Mexico?
09-24-2022 12:20 PM
You might want to try asking support to credit you back the cost of the previous charge. Then when you get to the states next month after buying add-on again, manually connect to T-Mobile to get the best chance of getting service.
09-24-2022 12:15 PM
@jumblbug There has e been lots of issues with roaming packages for a while now , you may want to look into prepaid US SIM cards for your next visit.. I’m sure more in depth solutions will be added shortly..
09-24-2022 12:14 PM
Were you connecting to a US network? It won’t work in Mexico by the way.
