4 hours ago
I seem to have lost a small number of bravos. Most likely because I didn’t deserve them. Is there a way to find these posts and find out what I did wrong so that I won’t repeat my mistake in the future?
3 hours ago
Thanks , that explains it.
4 hours ago
4 hours ago
They have been removed from “my profile”. Is that what you mean?
4 hours ago
I don't think that you did anything wrong. The leaderboard shows the last 30 days of your bravos received. You can look at different time frame like 3 months, 6 months, etc.
Also, sometimes if a post is moved to the Lounge section or archived, members may lose some bravos. Occasionally, the person that bravoed a post can choose to unbravo. Oracles do not have the ability to unbravo a post.
4 hours ago
@Wayworn if you're going off of the total bravo leader board its probably just the moving 30 days that are being calculated
