Re: No Data roll over !!
RiaW
I have that same plan being offered to me in BC. 6 GB of data, unlimited phone calls and text message. Text messaging all for $23 $2 less than I'm paying for 1 GB of data. What will I lose if I switch to a lower priced plan? The plan is being offered to me inside of my account. Nowhere does it say you need to be a new customer
Sansan
@RiaW  the only thing you would lose is rhe loyalty bonus that was given in March.  Right now however it wouldn't matter because that's expiring I'm about a week.
Just make sure you use change on Renewal.
EB0
@RiaW
You may not lose the loyalty data add-on 150 days, but even if you lose, it should not be a big deal, as it must likely is going to be expired in 30 days or less.
@RiaW
if it offers to you within your My Account, then you are the lucky one.  Get it while you can.  Use Change on Renewal to schedule a plan change on renewal to lock it in first.  You can change you mind before your renewal
If you change to a lower priced plan, you will lose your 150-days loyalty data bonus you got in March (if you have that).   Other bonuses you got from previous Christmas, if any, as well as paid add-on will be unaffected
