Why can't I submit a ticket
Unsatisfied
This seriously seems like a rabbit hole, intentionally.
I try and submit one after I sign into the community and it asks for verification, which I give, and it tells me its incorrect.
Someone please at public mobile please reach out to me.  This is absurd.
Edit - Was able to verify so I guess we will see if anyone gets back to me
Unsatisfied
Thank you for the contact info
statusquo
I'm sorry now I realize my link earlier doesn't have a second link but just a chatbot.  I'm sure I saw one somewhere but I'm glad esliv has given you the real link.
@Unsatisfied - please try again by opening a tab in incognito mode, perhaps they may help.
If ongoing issues, ontact Public Mobile Representatives (CSA) by submitting a message(ticket) to them here:
Private Message to Public Mobile Customer Support Agents (CSA)
pmbc
@Unsatisfied  Did you send a private message to CS_agent or via the chatbot?  They will ask for your PIN you set up for the PM account.  If it's incorrect, go to you account and update with a new one under Profile, PIN.
I found out a new account I set up had a different PIN than I configured (maybe I made a mistake?) so I just went to the PIN setting and set up the same PIN and it was fine after that.
statusquo
Maybe the chatbot is going through some technical problems and you might want to try sending a private message to the agents.  Try the second link from this page.  https://www.publicmobile.ca/get-help
