05-29-2019 04:58 PM - edited 01-05-2022 05:08 AM
When I enter my IMEI I got the following message:
Your device has not been reported as lost or stolen.
The Network Compatibility check cannot be performed at this time. Please try again later.
WHY?
HELP!
Thanks,
Daniel
05-29-2019 05:00 PM
You check compatability at willmyphonework.net.
05-29-2019 04:59 PM
@waternlava - Your best bet it to use willmyphonework.net for compatibility chack.
05-29-2019 04:59 PM
Public Mobile has partnered with willmyphonework.net as the new compatibility checker.If you can’t find your make and/ or model, provide feedback directly here.
05-29-2019 04:59 PM
Try this...www.willmyphonewwork.net
